Virtual Devices Interface
Indigo provides a Virtual Devices Interface type that provides users with several new device types, each discussed below. If you want to use Virtual Devices, make sure to enable them by selecting the Interfaces->Virtual Devices->Enable menu item.
- Select
New...button. You'll see theCreate New Devicedialog. - Select
Device Groups
Sprinkler Group
Virtual On/Off Devices
Execution Models
Automatic State Maintenance
Finally, your virtual device can maintain a state if you like. But, Action Groups can't directly manipulate state you say, right? Well, that's true. However, Action Groups can modify a variable. So, we've allowed you to select a variable and we'll monitor that variable for any change. If the value of the variable becomes "on" (or "true", "open", "1", "yes", "enabled"), we set the state of the virtual device to on. If the variable becomes "off" (or "false", "closed", "0", "no", "disabled"), then we set the state to off.
Scripting State Maintenance
Virtual Sensors
New to Indigo 2024.2 are Virtual Sensors. These plugin devices are linked to external Python scripts that send instructions to the Virtual Device so it can be used to track a desired status. The device also sends information back to the external script for further processing if needed.
Supported States
Script Locations
Controlling Scripts
# If you want to pass something to the Indigo Event Log, you will need to import the
import logging
def virtual_sensor_status(device: indigo.Device, action_props: dict) -> dict:
:action_props: any action object properties provided [dict]
:returns: updated sensor values [dict]
payload = dict()
return payload
*device* -- in this context, the *device* parameter will contain a copy of the Virtual Sensor device that is linked to the script.
*action_props* -- in this context, the *action_props* parameter will contain any props passed from the Indigo Action that caused the Virtual Sensor device to update. If the device was updated by a Send Status Request or a "generic" Indigo Action refresh call, action_props will be an empty dictionary.
Triggers and Actions
The *indigo.actionGroup.execute* API command message doesn't include action props, so the *action_props* property above will be an empty dict. You can execute this command message from both the Websocket and HTTP APIs.
"objectId": 123456789
The *plugin.executeAction* API command message can include optional props, and is currently only available in the HTTP API command space.
"actionId": "some_plugin_action", # the ID of the plugin action found in the plugin's Actions.xml file
"deviceId": 12345678, # the device ID targeted by the plugin action (not all actions will require a device ID.
"waitUntilDone": True
