Node Red Example
The following example shows how to configure a Node Red flow that uses the Indigo Web Server (IWS) API to operate a lamp device. The example is only meant to show how to use a self-signed certificate and public key to enable the flow to connect to the IWS using *https* instead of *http* when using the IWS on a local network via *10.0.1.123*, *127.0.0.1*, or *localhost* (using the API via the Indigo Reflector Service uses a different CA-approved security certificate and the flow is configured the same as it would be using any API via *https*).
{ width=600 }
Using the flow via *https* requires a few settings. Enter the preferred URL to point at the local IWS address *10.0.1.123*, *127.0.0.1*, or *localhost* with the URL:
for example,
{ width=400 }
/Library/Application Support/Perceptive Automation/Indigo 2024.2/Web Assets/cert/
{ width=400 }
Several other screenshots complete the example:
{ width=400 } |
{ width=400 } |
{ width=400 } |
{ width=400 } |
{ width=400 } |
