Actions
Action Base Class
Complementary Delays
Complementary Actions
Action Complement
*actionType = ControlLightOrAppliance* \ *deviceAction = TurnOff* \ *deviceAction = TurnOn* \ *deviceAction = Toggle* *actionType = ControlLightOrAppliance* \ *deviceAction = TurnOn* \ *deviceAction = TurnOff* \ *deviceAction = Toggle*
*actionType = ControlLightOrAppliance* \ *deviceAction = TurnOff* \ *deviceAction = TurnOn* *actionType = ControlLightOrAppliance* \ *deviceAction = TurnOn* \ *deviceAction = TurnOff*
*actionType = DisableSchedule* *actionType = EnableSchedule*
*actionType = DisableTrigger* *actionType = EnableTrigger*
*actionType = EnableSchedule* *actionType = DisableSchedule*
*actionType = EnableTrigger* *actionType = DisableTrigger*
ControlDimmerRelayAction
This class represents an action to control a dimmer (light) or relay (appliance) module.
complementDelay integer the number of seconds to delay before issuing the complementary action (0 for no action) - see Complementary Delays for details
deviceAction kDimmerRelayAction this is the command to send to the device
actionValue integer if *deviceAction* is in [Brighten, Dim, SetBrightness] then this is the value - delta percentage for the first two, absolute percentage for the latter
Dimmer Relay Action Enumeration
indigo.kDimmerRelayAction
Value Description
AllLightsOff turn off all dimmer (light) devices
AllLightsOn turn on all dimmer (light) devices
AllOff turn off all dimmer (light) and relay (appliance) devices
BrightenBy brighten a dimmer (light) device by the amount specified in the deviceValue property
DimBy dim a dimmer (light) device by the amount specified in the deviceValue property
SetBrightness set a dimmer (light) device to the brightness specified in the deviceValue property
Toggle toggle the on/off state of a dimmer (light) or relay (appliance) device
TurnOff turn off a dimmer (light) or relay (appliance) device
TurnOn turn on a dimmer (light) or relay (appliance) device
RequestStatus send a device a status request
DisableScheduleAction
DisableTriggerAction
EmailAction
complementDelay integer the number of seconds to delay before issuing the complementary action (0 for no action), in this case an *DisableScheduleAction* - see Complementary Delays for details
EnableTriggerEventAction
ExecuteGroupAction
ExecuteScriptAction
InputOutputAction
index integer if *action* is *TurnOffOutput*, *TurnOnOutput*, the index of the input or output to control
indigo.kIOAction
Value Description
TurnOffOutput turn off the output specified by index
TurnOffAllOutputs turn off all outputs
TurnOnOutput turn on the output specified by index
RequestStatusAll request status of all hardware input/outputs
RequestAnalogInputValues request all analog input values from the device
RequestBinaryInputsStatus request all binary input statuses
RequestBinaryOutputsStatus request all binary output statuses
RequestSensorInputValues request all sensor input values
ModifyVariableAction
Variable Action Enumeration
indigo.kVariableAction
Value Description
DecrementValue decrement the variable value by 1
IncrementValue increment the variable value by 1
SetValue set the variable to the *variableValue* property
PluginAction
SendInsteonGroupCommandAction
group integer this is the group number to send *command* to
indigo.kIOAction
Value Description
InstantOff send the instant (fast) off command to group ignoring ramp rate
InstantOn send the instant (fast) on command to group ignoring ramp rate
Off send the off command to group
On send the on command to group
SprinklerAction
zoneDurations list of float list of floats that represent the durations in minutes for each zone to schedule - used when *sprinklerAction* is *runSchedule*
zoneIndex integer the zone to turn on - used when *sprinklerAction* is *zoneOn*
Sprinkler Action Enumeration
indigo.kSprinklerAction
Value Description
NextZone set sprinkler to the next zone
PauseSchedule pause a sprinkler schedule
PreviousZone set sprinkler to the previous zone
ResumeSchedule resume a sprinkler schedule
RunSchedule run a sprinkler schedule
Stop stop a sprinkler schedule and turn off all zones
ZoneOn turn on a single zone
RequestStatusAll request status of all valves
ResetInterfacesAction
ThermostatAction
actionMode kFanMode \ OR \ kHvacMode if action is SetFanMode, then a kFanMode enumeration \ if action is SetHvacMode, then a kHvacMode enumeration
actionValue float if action is *Decrease* or *Increase*, the amount to increase/decrease the setpoints \ if action is *Set**, the temperature to set the setpoint to
Thermostat Action Enumeration
indigo.kThermostatAction
Value Description
DecreaseCoolSetpoint decrease setpoint by value
DecreaseHeatSetpoint decrease setpoint by value
IncreaseCoolSetpoint increase setpoint by value
IncreaseHeatSetpoint increase setpoint by value
SetCoolSetpoint set the setpoint to value
SetFanMode set the fan mode to mode
SetHeatSetpoint set the setpoint to value
SetHvacMode set the hvac mode to mode
RequestStatusAll request all current values from the thermostat
RequestMode request the current mode of the thermostat
RequestEquipmentState request the current operational state of the compressor, furnace, etc.
RequestTemperatures request all current temperatures from the thermostat
RequestHumidities request all current humidities from the thermostat
RequestDeadbands request the current deadband ranges from the thermostat
RequestSetpoints request all current setpoints from the thermostat
