Deletion Dependencies
When an object (Device, Trigger, Schedule, Action Group, Control Page, or Variable) is deleted, you will be presented a dialog to confirm. If there are any other objects that are dependent on the object you're deleting, the dialog will warn you that the dependencies will be deleted or otherwise modified.
