Folders
| Property |
Type |
Description |
id |
integer |
the unique id of the folder, assigned on creation by IndigoServer |
name |
string |
the name of the folder - no two folders in the same namespace (i.e. indigo.devices) can have the same name |
remoteDisplay |
boolean |
should this folder be displayed in remote clients (IWS, Indigo Touch, etc) |
Commands (indigo..folder.)
The commands to manipulate folders are within the object lists defined in the IOM Overview page (indigo.devices.folder., indigo.variables.folder., etc).
indigo.variables.folder.create("Folder Name Here") |
| Parameters |
| Parameter |
Required |
Type |
Description |
name |
Yes |
string |
the name of the folder |
Delete the specified folder.
indigo.devices.folder.delete(123, deleteAllChildren=True) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the folder to delete |
deleteAllChildren |
No |
boolean |
a boolean to specify whether all objects contained in the folder should be deleted as well - defaults to False |
indigo.controlPages.folder.duplicate(123, duplicateName="New Name") |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the folder to duplicate |
duplicateName |
No |
string |
name for the newly duplicated folder |
indigo.devices.folder.displayInRemoteUI(123, value=True) |
indigo.schedules.folder.displayInRemoteUI(123, value=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer |
id or instance of the folder |
value |
Yes |
boolean |
True to display the folder on remote user interfaces or False to hide it |
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
