Send Scene ON
This command will send an INSTEON Scene ON command to the specified PowerLinc scene.
indigo.insteon.sendSceneOn(11) |
indigo.insteon.sendSceneOn(11, sendCleanUps=False) |
indigo.insteon.sendSceneOn(11, suppressLogging=True) |
indigo.insteon.sendSceneOn(11, updateStatesOnly=True) |
indigo.insteon.sendSceneOn("working in office scene") |
indigo.insteon.sendSceneOn("working in office scene", sendCleanUps=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
either the scene number or the scene name - we encourage numbers since they won't change and the scene names can. |
sendCleanUps |
No |
boolean |
a boolean indicating if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might affect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True) |
suppressLogging |
No |
boolean |
a boolean indicating if entries in the event log should be suppressed (default is False) |
updateStatesOnly |
No |
boolean |
use if you only want Indigo's internal device state representation to be updated - no actual INSTEON command will be sent on RF or the power line (default is False) |
Send Scene OFF
This command will send an INSTEON Scene OFF command to the specified PowerLinc scene.
indigo.insteon.sendSceneOff(11) |
indigo.insteon.sendSceneOff(11, sendCleanUps=False) |
indigo.insteon.sendSceneOff(11, suppressLogging=True) |
indigo.insteon.sendSceneOff(11, updateStatesOnly=True) |
indigo.insteon.sendSceneOff("working in office scene") |
indigo.insteon.sendSceneOff("working in office scene", sendCleanUps=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
sendCleanUps |
No |
boolean |
suppressLogging |
No |
boolean |
updateStatesOnly |
No |
boolean |
Send Scene Fast ON
This command will send an INSTEON Scene Fast ON command to the specified PowerLinc scene.
indigo.insteon.sendSceneFastOn(11) |
indigo.insteon.sendSceneFastOn(11, sendCleanUps=False) |
indigo.insteon.sendSceneFastOn(11, suppressLogging=True) |
indigo.insteon.sendSceneFastOn(11, updateStatesOnly=True) |
indigo.insteon.sendSceneFastOn("working in office scene") |
indigo.insteon.sendSceneFastOn("working in office scene", sendCleanUps=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
sendCleanUps |
No |
boolean |
suppressLogging |
No |
boolean |
updateStatesOnly |
No |
boolean |
Send Scene Fast OFF
This command will send an INSTEON Scene Fast OFF command to the specified PowerLinc scene.
indigo.insteon.sendSceneFastOff(11) |
indigo.insteon.sendSceneFastOff(11, sendCleanUps=False) |
indigo.insteon.sendSceneFastOff(11, suppressLogging=True) |
indigo.insteon.sendSceneFastOff(11, updateStatesOnly=True) |
indigo.insteon.sendSceneFastOff("working in office scene") |
indigo.insteon.sendSceneFastOff("working in office scene", sendCleanUps=False) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
integer or string |
sendCleanUps |
No |
boolean |
suppressLogging |
No |
boolean |
updateStatesOnly |
No |
boolean |
