  • To change a device's state on the server, use myDevice.updateStateOnServer(key="keyName", value="Value")
Device Base Class
Device Base Class Properties
address string No the address for the device
buttonGroupCount integer No the number of groups (or buttons in the case of the RemoteLinc and ControLinc) that the controller supports - currently used only for INSTEON devices - 0 for other devices
description string Yes a description of the device as specified by the user
deviceTypeId string No the typeId specified in the Devices.xml (or it’s documentation) - only used for plugin defined devices
enabled boolean No is the device enabled - set using the indigo.device.enable() method
folderId integer No the unique ID of the folder this device is in (0 if it's not in a folder) - use moveToFolder() method to change
globalProps dictionary No an indigo.Dict() representing all name/value pairs associated with this device - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details
id integer No id or instance of the device, assigned on creation by IndigoServer
lastChanged datetime No the last date/time that the device was changed - populated by IndigoServer
model string No the model name of the device - defined either by Indigo based on type or by the plugin's device definition
name string Yes the unique name of the device - no two devices can have the same name
pluginId string No if protocol is Plugin, the string ID for the plugin
pluginProps dictionary No an indigo.Dict() representing the name/value pairs defined by your plugin for the device - plugin developers should publish this information if you want other plugins/scripts to create devices of this type - see About Plugin Properties below for details - use replacePluginPropsOnServer() method to change
protocol kProtocol No an enumeration specifying the protocol of the device - see protocol enumeration below for possible values
remoteDisplay boolean Yes should this device be displayed in remote clients (IWS, Indigo Touch, etc) - may also be set with indigo.device.displayInRemoteUI()
states dictionary No returns an indigo.Dict() of device states - the key is the state id and the value is the value. Note that enumerated states will have not only the state, but also each option for the state. So, for instance, if I had a state called status and it had 3 options (online, offline, error), then you'd not only have status as a key, but also status.online, status.offline, and status.error as keys in the dictionary. This is so that you can test each state enumeration independently in trigger actions (e.g. status.online is true).
supportsAllLightsOnOff boolean No indicates that this device should react to all lights On and all lights Off commands - always False for plugin defined devices
supportsAllOff boolean No indicates that this device should react to all Off commands - always False for plugin defined devices
supportsStatusRequest boolean No indicates if the device supports querying the status - always False for plugin defined devices
Protocol Enumeration
indigo.kProtocol
Value Description
*X10* identifies the device as an X10 device
dev=indigo.devices[123]
dev.replacePluginPropsOnServer({"pollInterval":10,"checkForUpdates":True})
localPropsCopy.update({"pollInterval":10,"checkForUpdates":True})
dev.pluginProps.update({"pollInterval":10,"checkForUpdates":True})
About Custom Device States
    <State id="playStatus">
    <State id="sep1">
    <State id="playlist">
        <ValueType>String</ValueType>
    <State id="album">
    <State id="artist">
    <State id="track">
    <State id="volume">
    <State id="shuffle">
It's actually pretty simple. When your plugin detects a change in one of the states, you just call the updateStateOnServer("id",value="value") method. Here are some examples for setting the state based on the above state definitions:
# to update the volume state
someMusicServer.updateStateOnServer("volume", value=50)
# to update the track name
someMusicServer.updateStateOnServer("track", value="Cluster One")
# to update the album name
someMusicServer.updateStateOnServer("album", value="The Division Bell")
# to update the artist name
someMusicServer.updateStateOnServer("artist", value="Pink Floyd")
# to update the playStatus
someMusicServer.updateStateOnServer("playStatus", value="playing")
someMusicServer.updateStateOnServer("shuffle", value=True)
The updateStateOnServer method has 2 optional parameters: decimalPlaces (integer) and triggerEvents (boolean). When updating floating point state values use the decimalPlaces parameter to specify the number of fractional digits to store and display. For example:
someThermmostatDevice.updateStateOnServer("mainTemp" value=76.1234, decimalPlaces=2)
Commands (indigo.device.*)
All Off
indigo.device.allOff()
Enumerated Type Description
Insteon specify all INSTEON devices that support ON/OFF
X10 specify all X10 devices that support ON/OFF
ZWave specify all Z-Wave devices that support ON/OFF
HouseCodeA specify all X10 devices in house code A
HouseCodeB specify all X10 devices in house code B
HouseCodeC specify all X10 devices in house code C
HouseCodeD specify all X10 devices in house code D
HouseCodeE specify all X10 devices in house code E
HouseCodeF specify all X10 devices in house code F
HouseCodeG specify all X10 devices in house code G
HouseCodeH specify all X10 devices in house code H
HouseCodeI specify all X10 devices in house code I
HouseCodeJ specify all X10 devices in house code J
HouseCodeK specify all X10 devices in house code K
HouseCodeL specify all X10 devices in house code L
HouseCodeM specify all X10 devices in house code M
HouseCodeN specify all X10 devices in house code N
HouseCodeO specify all X10 devices in house code O
HouseCodeP specify all X10 devices in house code P
| Command Syntax Examples | | --- | | python indigo.device.create(protocol=indigo.kProtocol.Plugin, address="F8", name="Device Name Here", description="Description Here", pluginId="com.mycompany.pluginId", deviceTypeId="myDeviceTypeId", props={"propA":"value","propB":"value"}, folder=1234) |
*address* No string the address of the X10 device - plugins must set an address property in their property dictionary
*description* No string the description of the device
*deviceTypeId* Yes string the id of the device type – defined by the plugin or one of the defined X10 devices FIXME link here
*pluginId* No string the plugin ID - defaults to your plugin's id if in a Server Plugin
*props* No dictionary this is the properties for the device - they will be inserted in to the pluginId's property space as supplied above. If you are creating a device of a type defined in a different plugin, it's that plugin's id and properties.
*protocol* Yes kProtocol the protocol for the device (indigo.kProtocol.Plugin or indigo.kProtocol.X10)
*folder* No integer id or instance of the folder in which to put the newly created device
indigo.device.delete(123)
indigo.device.duplicate(123, duplicateName="New Name")
Enable/Disable
| Command Syntax Examples | | --- | | python indigo.device.enable(123, value=True) #enable indigo.device.enable(123, value=False) #disable |
Status Request
Toggle
indigo.device.toggle(123)
Turn Off
indigo.device.turnOff(123)
Turn On
indigo.device.turnOn(123)
Here’s a side by site comparison of using various device properties in Python and AppleScript:
Python AppleScript
```python
# Creating a device
name="Office Lamp",
address="F7",
|text
-- Creating a device
address:"F7",¬
```python
# Getting a device
|text
-- Getting a device
```python
|text
-- Logging a message if it’s an X10 device
log "device is an X10 device"
end if
```python
if (myDevice.remoteDisplay):
|text
-- Logging a message if it’s showing in Indigo Touch
end if
```python
|text
-- Folder ID is not available in AppleScript
```python
Turning off all devices in X10 house code A
Turning off all INSTEON devices
indigo.device.allOff(indigo.kAllDeviceSel.Insteon) |text -- Turning off all devices (dimmer and relay) all off
-- Turning off all devices in X10 house code A all lights off "A"
-- Turning off all INSTEON devices is not available in -- AppleScript ``` |
DimmerDevice
ledStates list No this is a list of booleans that represent the state of LEDs on the device. So, to check to see if LED 3 is on you'd check dev.ledStates[2] (Python arrays are 0-based so the first element is element 0). Currently, only KPL devices use this array - however, future devices may use it as well so you should probably check the length first to make sure that the LED you're looking for is actually there. Use the len(dev.ledStates) method to see how many entries there are before you access a specific index.
onState boolean No indicates whether the device is on - set using commands below
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
direct parameter No kAllDeviceSel enumerated value to indicate which devices to turn off, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description
All Lights On
indigo.dimmer.allLightsOn()
Brighten
indigo.dimmer.brighten("Office Lamp")
indigo.dimmer.brighten(123)
indigo.dimmer.brighten("Office Lamp", by=50, delay=4)
*by* No integer relative amount to brighten by where brightness is 0-100
*delay* No integer number of seconds to delay before executing the brighten command
Dim
indigo.dimmer.dim("Office Lamp")
indigo.dimmer.dim(123)
indigo.dimmer.dim("Office Lamp", by=50, delay=4)
*by* No integer relative amount to dim by where dimness is 0-100
*delay* No integer number of seconds to delay before executing the dim command
Set Brightness
*value* Yes integer absolute value to set the brightness to on a scale of 0-100
Set LED State
*index* Yes integer the index of the button. Recall that Python-based arrays are 0-based, so the index is also 0-based. That is, the first object in an array is object 0.
*value* Yes boolean True to turn on the LED, False to turn it off
*suppressLogging* No boolean True to suppress logging (defaults to False)
*updateStatesOnly* No boolean True to only update Indigo's internal state - no command will be sent to the KPL (defaults to False)
Set On State
Here’s a side by site comparison of dimmer properties in Python and AppleScript:
Python AppleScript
```python
# Getting a device
|text
-- Getting a device
```python
(myDevice.onState)):
|text
-- Set a device’s brightness to 75 if it’s currently
end if
```python
|text
-- Brighten a light by 25% after 10 minutes
```python
|text
end if
```python
myDevice.folderId
# OR
``` -- Folder ID is not available in AppleScript
InputOutputDevice
analogInputs list of integer No a list of the current analog input values, one per input
binaryInputs list of boolean No a list of the current binary input values, one per input
binaryOutputs list of boolean No a list of the current binary output values, on per output (max 12 total outputs)
sensorInputs list of integer No a list of the current sensor input values, one per input
Commands (indigo.iodevice.*)
Set Binary Output
*index* Yes integer 0-based index of the output to change - should be less than the *binaryOutputCount* property of the device
*value* Yes boolean True to turn the output on, False to turn it off
Python AppleScript
```python
index=1,
value=False)
-- to false set theBinaryInputs to binary inputs ¬ of device "EZIO8SA" if not item 3 of theBinaryInputs then set theBinaryOutputs to binary outputs ¬ of device "EZIO8SA" set item 1 of theBinaryOutputs to false set binary outputs of device ¬ "EZIO8SA" to theBinaryOutputs end if|
SensorDevice
Some sensor devices, like motion sensors, are treated differently in Indigo. They aren't generally directly controllable and are considered input devices.
They typically send a command of some type when they detect some condition and send another command when they stop detecting it. However, dealing with them in Indigo as if they maintain state is much more useful in many cases. So, Indigo will attempt to maintain a virtual state for each motion sensor if configured that way. Currently, the following devices fall under this category:
  • X10 Motion Sensors
Other sensor types, such as an energy meter (iMeter solo), do maintain some state information (like current load in Watts). Indigo maintains additional virtual states for these types of devices as well though, for example to track the kWh of energy used from a base time stamp.
onState boolean No indicates that the device is currently detecting motion
energyInputCount integer No number of energy (current) monitoring inputs this device supports
energyInputs list of integer No a list of the energy input values in Watts, one per input
accumEnergyTotals list of float No a list of the energy used in kWh since the last base time specified in accumEnergyBaseTimes, one per input
accumEnergyTimeDeltas list of integer No a list of the time delta in seconds since the last base time, one per input
accumEnergyBaseTimes list of datetime No a list of the base times from which to calculate energy totals (accumEnergyTotals), one per input
Commands (indigo.sensor.*)
Set On State
Reset Accumulated Energy Totals
Resets the accumEnergyTotals, accumEnergyTimeDeltas values for all inputs properties and changes the accumEnergyBaseTimes to the server's current datetime.
indigo.sensor.resetAccumEnergyTotals(123)
Because this can't be done in AppleScript, we've just provided an example in Python:
# Log to the Event Log the current kWh total for an energy meter (ID 123):
dev = indigo.devices[123]
indigo.server.log("current kWh total: " + str(dev.accumEnergyTotals[0]))
# Then reset the accumulative totals and log again (should be 0):
indigo.sensor.resetAccumEnergyTotals(dev)
dev.refreshFromServer(waitUntilServerIdle=True)
indigo.server.log("reset kWh total: " + str(dev.accumEnergyTotals[0]))
RelayDevice
*onState* boolean indicates whether the device is on
Commands (indigo.relay.*)
Set LED State
Python AppleScript
```python
# Toggle the device
|text
-- Toggle the device
toggle device “Office Lamp”
SprinklerDevice
activeZone integer No the number of the active zone, -1 if off (0=zone 1, 1=zone 2, etc)
zoneCount integer No the number of zones available for this sprinkler
zoneNames list of string No list of zone names, starting at zone 1 through zone [*zoneCount*] - you must include *zoneCount* strings in the list
zoneMaxDurations list of integer No list of zone durations in minutes, starting at zone 1 through zone [*zoneCount*] - you must include *zoneCount* integers in the list
zoneScheduledDurations list of integer No list of currently active zone durations in minutes if a schedule is running (empty list if no schedule is running), starts at zone 1 through zone [*zoneCount*] - you must include *zoneCount* integers in the list
Commands (indigo.sprinkler.*)
Next Zone
Pause Schedule
indigo.sprinkler.pause(123)
Previous Zone
Resume Schedule
indigo.sprinkler.resume(123)
Run Schedule
Run a sprinkler schedule.
schedule Yes list of integer list of integers representing the number of minutes to run for each zone - the list must have [zoneCount] elements, with 0 for any zone that shouldn’t run
Stop Schedule
indigo.sprinkler.stop(123)
Turn On Zone
Turn on a specific zone.
indigo.sprinkler.turnOnZone(123, index=2)
*index* Yes integer 0-based index of the zone to turn on
Python AppleScript
```python
# run schedule
|text
-- AppleScript doesn't support directly running a schedule, so
-- then execute that.
-- run schedule
with properties ¬
end if
set zone durations of ¬
to [10, 15, 8, 0, 0, 0, 0, 0]
execute group actionGroupName
ThermostatDevice
Thermostats have a wide variety of capabilities that we’ve tried to boil down to some specifics. They can have multiple temperature and humidity sensors, they generally have a fan mode, an HVAC mode (heating, cooling, etc) and associated setpoints. Note:some thermostats don’t support getting the following values: coolIsOn, fanIsOn, and heatIsOn - for those thermostats those properties will always be False.
coolIsOn boolean No is the cooling system (compressor) currently running
coolSetpoint float No current cool setpoint value
fanMode kFanMode No the operating mode for the fan attached to the thermostat
fanIsOn boolean No is the fan currently running
heatIsOn boolean No is the heater currently running
heatSetpoint float No current heat setpoint value
humidities list of float No a list of floating point values representing the current values of all humidity sensors connected to the thermostat
humiditySensorCount integer No number of humidity sensors this thermostat supports
hvacMode kHvacMode No the operating mode for the HVAC system attached to the thermostat
temperatureSensorCount integer No number of temperature sensors this thermostat supports
temperatures list of float No a list of floating point values representing the current values of all temperature sensors connected to the thermostat
Fan Mode Enumeration
*indigo.kFanMode*
Value Description
AlwaysOn signal the fan that it should be running continuously
Auto signal the fan that it should only run when the HVAC system needs it to be running
HVAC Mode Enumeration
*indigo.kHvacMode*
Value Description
Cool the hvac system is only reacting to cool setpoints
HeatCool the hvac system is reacting to both cool and heat setpoints
Heat the hvac system is only reacting to and heat setpoints
Off the hvac system is turned off
ProgramHeatCool the hvac system is executing it’s built-in automatic program, which usually responds to both heat and cool setpoints
ProgramCool the hvac system is executing it’s built-in cooling program
ProgramHeat the hvac system is executing it’s built-in heating program
Decrease Cool Setpoint
value Yes integer number of degrees to decrease the cool setpoint
Decrease Heat Setpoint
*value* Yes integer number of degrees to decrease the heat setpoint
Increase Cool Setpoint
*value* Yes integer number of degrees to increase the cool setpoint
Increase Heat Setpoint
*value* Yes integer number of degrees to increase the heat setpoint
Set Cool Setpoint
*value* Yes integer the absolute temperature of the setpoint
Set Fan Mode
Adjust the fan mode.
*value* Yes kFanMode the absolute temperature of the setpoint
Set Heat Setpoint
Set HVAC Mode
Adjust the HVAC mode.
indigo.thermostat.setHvacMode(123, value=indigo.kHvacMode.HeatCoolOn)
*value* Yes kHvacMode HVAC mode identifier
Python AppleScript
```python
set the thermostat mode to auto
set the heat setpoint to 78
indigo.thermostat.setHeatSetpoint(123, value=78) |text -- increase the cool setpoint by 5 degrees set cool setpoint of device "Thermostat" to ¬ (cool setpoint of device "Thermostat") + 5
-- set the thermostat mode to auto set hvac mode of device "Thermostat" to heatCoolOn
-- set the heat setpoint to 78 set heat setpoint of device "Thermostat" to 78 ``` |
