Server Commands (indigo.server.*)
Commands that aren't associated with any specific object type are collected up in the indigo.server.* command namespace.
Calculate Sunrise
indigo.server.calculateSunrise() |
indigo.server.calculateSunrise(myDateObject) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
No |
datetime.date |
a *datetime.date* object representing the day to calculate the sunrise time for |
Calculate Sunset
indigo.server.calculateSunset() |
indigo.server.calculateSunset(myDateObject) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
No |
datetime.date |
a datetime.date object representing the day to calculate the sunrise time for |
Event Log List
indigo.server.getEventLogList() |
indigo.server.getEventLogList(lineCount=5) |
indigo.server.getEventLogList(showTimeStamp=False) |
indigo.server.getEventLogList(lineCount=5, showTimeStamp=False) |
indigo.server.getEventLogList(returnAsList=True, lineCount=5) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| returnAsList |
No |
boolean |
if true a list of dicts is returned containing individual log entry attributes; if false a string containing a textual description of the log lines is returned - the default is false |
| lineCount |
No |
integer |
the number of lines to return from the event log starting from newest and going backwards in time - the default is 1500 |
| showTimeStamp |
No |
boolean |
indicate whether every line should have its timestamp prepended to the log entry - the default is true |
Get Latitude and Longitude
| python
lat = latLong[0]
long = latLong[1] |
Get Plugin
myPlugin=indigo.server.getPlugin("com.company.pluginId") |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
string |
the id of the plugin to retrieve |
Get Serial Ports
indigo.server.getSerialPorts() |
indigo.server.getSerialPorts(filter="indigo.ignoreBluetooth") |
| Parameters |
| Parameter |
Required |
Type |
Description |
filter |
No |
string |
currently there’s only one valid filter: "indigo.ignoreBluetooth" which will remove the "Bluetooth-PDA-Sync" option from the list |
for posixPath in ports:
print(posixPath)
print(uiName)
# iterate through both
print(posixPath)
print(uiName)
Get Time
indigo.server.getTime() |
No Parameters
Log
indigo.server.log("Text to log") |
indigo.server.log("Text to log", type="myType") |
indigo.server.log("Text to log", isError=True) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
string |
this is the text that’s written to the log |
*type* |
No |
string |
a string representing the type - if it’s not included and is run from a Server Plugin, the name of the plugin will automatically be used |
*isError* |
No |
boolean |
if *True*, it will show up in red in the event log - default is *False* - if no *type* is included, the name of the plugin will automatically be used with " Error" appended |
Remove All Delayed Actions
indigo.server.removeAllDelayedActions() |
Send Email
indigo.server.sendEmailTo("my.address@example.com") |
indigo.server.sendEmailTo("my.address@example.com", subject="Subject of email", body="Body of email") |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
string |
a semicolon separated string of email addresses |
*subject* |
No |
string |
the subject of the email |
*body* |
No |
string |
the body of the email |
Speak
indigo.server.speak("text to speak", waitUntilDone=True) |
| Parameters |
| Parameter |
Required |
Type |
Description |
| direct parameter |
Yes |
string |
the string to speak |
*waitUntilDone* |
No |
boolean |
should the method call block until speaking is complete or should it just return immediately (queue up the speech) |
