EasyDAQ Relay Card Plugin
Cards Supported
  • USB24MxS (24 relays)
  • USBDIO24 (24 DIO channels)
Adding Cards to Indigo
Next choose the File->New Device... menu item, select Plugin from the Type popup control, and EasyDAQ Relay Card from the Plugin popup control, and choose the correct Model. Press the Edit Device Settings... button to configure the card:
Easydaq Settings Window Image
Controlling Relay and Digital Outputs
Easydaq Action Pagel Window Image
Some actions have additional options available via the Edit... button. For example, the Change Multiple Outputs action allows you to control (turn on, turn off, or toggle) all the outputs with a single, and very fast, action:
Easydaq Action Change Multi Window Image
Triggering Actions on a Digital Input Change
Indigo will automatically track all input and output channel states. To trigger an action when a particular channel state changes from OFF to ON (or ON to OFF) choose the File->New Trigger menu item, and select Device State Changed from the Type popup control. Next, select the Indigo device representing the EasyDAQ card you want to monitor, and then choose which channel change will cause the trigger:
Easydaq Trigger Device State Change Window Image
Preventing Floating Input Problems
Scripting Support
Action specific properties
Turn On Output
Action id: turnOnOutput
Properties for scripting:
if easyDaqPlugin.isEnabled():
Turn Off Output
Action id: turnOffOutput
Toggle Output
Action id: toggleOutput
All Outputs On
Action id: allOutputsOn
All Outputs Off
Action id: allOutputsOff
Action id: changeMultiple
channelSel# this is the command for the channel and must be one of the following: "turnOn", "turnOff", "toggle" - note that you should have separate properties for each channel, see example below for details
Support and Troubleshooting
