NOAA Weather
This is the official weather plugin for Indigo. You may create as many "Weather Station" devices as you like. Each station will have a variety of device states that hold information that can be used in triggers, conditions, and on control pages. NOTE: some information may not be available for any given station - if the data isn't available in the NOAA data feed, the value of that particular state will be "- data unavailable -".
Plugin Config
The NOAA Weather Plugin allows you to create Weather Station devices. To create a new one, switch to the device view and click the New... button. This will bring up the device edit dialog. Select Plugin from the Type: popup. Select NOAA Weather from the Plugin: popup, and select Weather Station from the Model: popup. Click on the Edit Device Settings... button and you'll see the Weather Station Config UI. Enter the NOAA station id in the text box at the top. You can click on the "Find NOAA Stations" to have a browser window open to the NOAA webpage where you can start your search.
Once you've found the station ID and entered it in the text field, click "Save". If we can successfully contact NOAA and get the station data, we'll close the dialog. If not we'll show you an error indicating that we couldn't get the station's data file. You should try another station if this happens or confirm that you entered the station id correctly.
Device States
Observation Date/Time- The last time the data was updated by NOAA. This field is in RFC822 Date/Time format (i.e. "Fri, 19 Aug 2011 11:51:00 -0500") so it can be parsed by other software if needed.Current Condition- The current condition in a word or twoCurrent Condition Icon- The current condition icon - Indigo ships with "NOAA Condition+.png" and it's children, one for each condition that's returned in this field. So, in the control page editor, select this state and "NOAA Condition+.png" and you'll have a nice conditions icon (images provided by NOAA)Visibility- Visibility in milesTemperature °F- Temperature in FahrenheitTemperature °C- Temperature in CelsiusTemperature String- Temperature in a human-readable string (i.e. "98.0 F (36.7 C)") - this is the state shown in the "State" column for a Weather Station deviceRelative Humidity- The relative humidityDew Point °F- Dew point in FahrenheitDew Point °C- Dew point in CelsiusDew Point String- Dew point in a human-readable stringHeat Index °F- Heat index in FahrenheitHeat Index °C- Heat index in CelsiusHeat Index String- Heat index in a human-readable stringWind Direction- Wind direction description in something close to human-readable formWind Degrees- Wind direction in degreesWind MPH- Wind speed in miles per hourWind Knots- Wind speed in knotsWind String- A description of the wind in human-readable formPressure (inches)- Pressure in inchesPressure (mbar)- Pressure in millibarsLocation- Location in human-readable formLatitude- LatitudeLongitude- Longitude
Scripting Support
Support and Troubleshooting
