Substitutions
Plugin writers can enable configuration text fields to accept special markup that will substitute a variable, device state, or timestamp value at runtime. Any string with the following markup will have an Indigo variable value substituted:
Variable Substitutions
%%v:VARID%%
Device Substitutions
%%d:DEVID:STATEID%%
Time Substitutions
%%t:"FORMAT SPECIFIER"%%
FORMAT SPECIFIER is the standard POSIX date/time specifier -- which must be surrounded by double quotes. For example, "%Y-%m-%d %H:%M" will yield:
2025-01-01 12:34
