Substitutions
%%v:VARID%%
So, for instance, if one of your actions is to use the Growl plugin to do a notification, in the title and/or description fields you could enter something like this:
Turn on the A/C unit - the outside temperature is %%v:VARID%%.
The value specified would be substituted just before the notification was sent.
%%d:DEVID:STATEID%%
