direct parameter Yes integer id or instance of the action group to delete
Display In Remote UI
*value* Yes boolean True to show the action group or False to hide it
*duplicateName* No string name for the new action group trigger
event_data No dict a dictionary instance that will get passed to all actions in the action group for processing
A note on event_data - Indigo will automatically add a source key to your dictionary to represent where the action execution came from:
  • "server" if it's something generated from the server itself (schedule execution, built-in trigger, etc)
  • "python" if it's something that comes through IPH that doesn't already have a source attached (scripts, plugins)
  • "api-http" if it came from the HTTP API and there wasn't already an included "source"
  • "api-websocket" if it came from the websocket API and there wasn't already an included "source"
However, if you include a source key in your event_data, we will not overwrite it, we'll just pass through whatever your value is.
Use this command to retrieve all the Indigo objects dependent on the action group. The command will return an indigo.Dict containing all the dependencies.
indigo.actionGroup.getDependencies(123)
*value* Yes integer id or instance of the folder to move the action group to
