Variables
name string the name of the variable - no two variable can have the same name and the name cannot contain whitespace
sharedProps dictionary API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use var.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you don't accidentally remove some other plugin's props).
Class Method
bool Boolean True will be returned if the value is one of these: "true", "on", "yes", and "1". False will be returned if the value is one of these: "false", "off", "no", and "0". If no default value is specified and the value can't be successfully converted, the method will return False.
Remember that accessing the value property of a variable object (*var.value*) will return a unicode string object so you don't need a conversion for that.
Class Method Examples
# Get a variable
unicodeValue = var.value
# Getting the boolean value
# Getting the integer value
# Getting the float value
Commands (indigo.variable.*)
direct parameter Yes string the name of the variable
Delete the specified folder.
indigo.variable.delete(123)
indigo.variable.getDependencies(123)
               ID : 552463741 (integer)
               ID : 296710860 (integer)
Update Value
# Create a new variable
# changing name property
newVar.name = "goodName"
newVar.replaceOnServer()
newVar.name = "goodName2"
# Getting a variable using its ID
# Getting a variable using its name
