The Indigo Reflector Service
About Reflectors
Reflectors provide:
- Hassle free setup:
Activating your Reflector
- Choose the
Indigo->Start Local Server...menu item. - Turn on the
Allow remote accesscheckbox and enter a User name and good Password. You will definitely want password authentication on since you are about to enable access to the Indigo web server from the Internet. - Turn on the
Enable secure internet access via Indigo Reflectorcheckbox. - Press the
Activate Reflectorbutton.
Lastly, switch back to the Indigo Start Local Server... dialog. It should now show that the reflector status is activated and will show a link to your new reflector URL. Press the Start Server button and that is it – Indigo will restart and automatically connect to your reflector! To access from the web, simply go to https://YOUR-REFLECTOR-NAME.indigodomo.net/.
Indigo 2025.1->Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset
Go->Go to Folder… - In the resulting dialog, copy and paste the following:
/Library/Application Support/Perceptive Automation/Indigo 2025.1/Preferences/ - In the resulting Finder window, delete the folder named
Bandwidth Limits
If you have a graphical Control Page in Indigo that uses the
Refreshing Imagecontrol type then use a longer refresh duration (30 minutes or longer) for the image, especially if you plan to frequently access the page remotely. -
Not leaving Indigo Touch or an Indigo web browser page running continuously while not viewing it. By closing the browser window or leaving Indigo Touch (home button), the requests through the reflector will stop which significantly reduces daily bandwidth usage.
Troubleshooting
- failed to create reflector connection: reflector not active - try the steps above to reset your reflector's activation
- reflector connection test failed: local server unreachable - check this forum post for the likely causes.
- Unable to authenticate with IndigoDomo.com (server might be down temporarily for maintenance) - you may be able to resolve the issue by:
- shutting down the Indigo Server,
- deleting the registration file located at
/Library/Application Support/Perceptive Automation/Indigo 2025.1/Preferences/Indigo Registration.indiPref, - restarting the Indigo Server, and
- when prompted, enter your Indigo Account information.
Reflectors may also be affected by a bad entry in your /etc/hosts file. Check this forum post for details.
Advanced Troubleshooting
If nothing else works or if directed by Indigo support, create a new topic in the reflectors forum detailing what you've tried and do the following:
Launch the Terminal application (inside
/Applications/Utilities/) -
Copy/paste each line below individually and hit the return key after each one:
id
cd /Library/Application\ Support/Perceptive\ Automation
cd Indigo\ 2025.1/IndigoServer.app/Contents/Resources/PlugIns/
ps -axww | grep "Indigo"
3. Select the entire results of the Terminal window (CMD-A) and copy/paste into Code tags (the icon that looks like this: </>).
- Copy/paste each line below individually into the Terminal window and hit the return key after each one:
./reflector_library_stub.py -m geturl -d ./reflector_library_stub.py -m tunnel -d
- Wait 3 minutes. It can take a while for the network errors we are trying to catch to be reported. Then enter again:
- Select the entire contents of the Terminal window (CMD-A) again and copy/paste results into another section with Code tags.
