Install the FTDI VCP Drivers
Connecting the Interface
  1. Choose Indigo 2025.1->Preferences... menu, then make sure the Interfaces tab is selected.
If you click on the Interface Options... button, you'll see something like this:
First, make sure that Indigo has enabled communication with the interface. If Indigo is not online with the interface, then choose the Interfaces->INSTEON/X10 Power Line->Enable menu item. See connecting the Interface above for more details.
To add a new Insteon device:
  2. Press the New... button at the top of the Home window and select INSTEON from the Type popup.
Insteon Device Detail Image
Define Insteon Dialog Image
Start Sync Dialog Image
Use this dialog to resync a device when its links have been altered outside of Indigo. You may be asked to use this dialog by technical support when troubleshooting device problems.
Replacing a Device
The INSTEON protocol has linking built-in as part of its core functionality. The idea is that one device, a controller in INSTEON speak, can be linked to another device, a responder, then from that point forward the controller device sends its command directly to the responder device. So, for instance, you can link a KeypadLinc button to a SwitchLinc so that when you press the button on the KPL the SwitchLinc responds. That's normally done by pressing various buttons on each device in specific ways until the link is established.
Device Links Dialog Image
Device Links Example Image
Manage Powerlinc Scenes Image
Defining the Scene
Executing the Scene
Resetting your PowerLinc
  5. Release the button
Replacing Your PowerLinc
The Interfaces->INSTEON/X10 Power Line submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI:
Insteon Menu Image
Execute Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
if insteonPlugin.isEnabled():
    actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
Set Siren Alarm Sound
Set Siren LED Mode
Set OutletLinc Load Sense
Troubleshooting
If you can't get a device to sync, follow these steps:
  1. Hold down the shift & option keys while selecting the Interfaces->INSTEON/X10 Power Line->Configure... menu item
  2. In the resulting dialog, check the box next to LILO debug logging (leave the dialog open)
  3. Switch back to the home window and try the define and sync with the AL again - you'll see a lot of debugging information show up in the Event Log window.
  4. Starting with the first part of the define and sync, copy/paste all the event log lines into an email to support@indigodomo.com.
  5. Switch back to the INSTEON Debugging window and uncheck the LILO debug logging checkbox (and close the dialog)
