Indigo Object Model Reference
About this Reference
# some code here
# that does something
| Term | Meaning |
Introduction
For Scripters and Developers:
For Developers:
| Devices | ||||
| Schedule | ||||
Schedule (indigo.Schedule) |
| Triggers | ||||
| DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger) | indigo.devStateChange.* | manipulate a device state change trigger | ||
| Action Groups | ||||
| Variables | ||||
| General Commands | ||||
There are a few classes that are special. One is Action and it’s subclasses (collectively referred to as "actions"). Why are these classes different? Because outside of the trigger, schedule, action group, or control page that they’re associated with they aren’t individually addressable in the IndigoServer: for instance, there is no way to identify an action without first identifying the trigger that it’s associated with.
IOM Class Hierarchy
Indigo specific data types
- keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
python_dict = my_indigo_dict.to_dict() # recursively convert an indigo.Dict instance to a python dict instance
python_list = my_indigo_list.to_list() # recursively convert an indigo.List instance to a python list instance
Built-in objects
| Object | Description |
The other additional method is subscribeToChanges(). This method doesn't return anything - rather, it tells the IndigoServer that your plugin wants notification of all changes to the specific object type. Use this method sparingly as it causes a significant amount of traffic between IndigoServer and your plugin. What kind of plugins would use this? One good example is a logging plugin - one that's logging activity within Indigo (like our SQL Logger). Another example is a plugin that's doing some kind of scene management - you would probably want to issue a indigo.devices.subscribeToChanges() at plugin start so that you'll always be notified when any device changes - you can then determine if your scene "state" has changed and act accordingly. Note that subscribeToChanges() only reports actual changes to devices - so for instance when a light turns ON you'll get a notification. If the light is commanded to turn ON again, you won't get the notification because the device state didn't change.
Object Events
Lower-level Events
if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
# do stuff with dev here
Triggers also have filters:
| Filter | Description |
for var in indigo.variables:
# all variables
Common Python Exceptions
| Possible Exceptions | |
ArgumentError |
IndexError |
KeyError |
PluginNotFoundError |
TypeError |
ValueError |
Classes and Commands
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
Object Dictionaries
>>> dev = indigo.devices[123]
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
<'indigo.Device'>
>>> dev_dict = dict(dev)
<class 'dict'>
- Device classes
- Trigger classes
- Action classes
- Action Group class
- Variable class
- Folder class
Utility Classes and Functions
Classes
| Name | Base | Description |
FileNotFoundError |
Exception |
This is a useful exception if you handle files in any way. There is no built-in processing to catch such exceptions, it's just a useful exception to use. |
IndigoJSONEncoder |
JSONEncoder |
Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder)) |
Functions
Return Static File
| Parameters | |||
file_path |
Yes | string | a string that represents the path to a file |
*status* |
No | int | the HTTP status code to return, defaults to 200 |
*path_is_relative* |
No | boolean | is the path a full path or relative to the plugin, defaults to True |
*content_type* |
No | string | a string to return as the mime type of the content, returns the appropriate type based on the file extension if none is specified |
"status": 404,
"headers": {
"Content-Type": "text/html"
"file_path": "/Library/Application Support/Perceptive Automation/Indigo 2025.1/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
| Parameters | |||
address |
Yes | string | a string that represents an email address |
Boolean Functions
There are two functions available that will help scripters and developers in converting and using strings that represent boolean values, but are not True and False.
The first is str_to_bool(val: str). It will convert the string passed in to a boolean value and return it. We use the following map and it's reverse to do the mapping:
BOOL_MAP_TRUE: dict[str, str] = {
"y": "n",
"yes": "no",
"t": "f",
"true": "false",
"on": "off",
"1": "0",
"open": "closed",
"locked": "unlocked",
indigo.utils.str_to_bool("closed") |
| Parameters | |||
val |
Yes | string | a string that represents a boolean value as mapped above |
Returns True for true values, False for values that are false, and will raise an indigo.utils.ValueError if the input can't be successfully converted.
The second is reverse_bool_str_value(val: str). It will return the string that represents the opposite boolean value using the map above.
indigo.utils.reverse_bool_str_value("closed") |
| Parameters | |||
val |
Yes | string | a string that represents a boolean value for which we want the opposite string value |
This example returns open since that's the opposite of closed. It will raise an indigo.utils.ValueError if the input can't be successfully found.
