Triggers
Trigger Base Class
Unlike Devices, you can't call create() in the the trigger base class command namespace (indigo.trigger.*). Rather, each subclass has its own create() method that takes the appropriate arguments for that trigger type.
You will also need to implement triggerStopProcessing(self,trigger) so that you can remove disabled/deleted triggers from your watch list. So, the Server isn't really involved at all with the trigger firing (except to execute the trigger when you tell it to) - it only notifies your plugin of events its supposed to be watching for and your plugin does the rest.
| Property | Type | Writable | Description | |
description |
string | Yes | description of the trigger | |
enabled |
boolean | Yes | true if this trigger is enabled | |
folderId |
integer | No | unique ID of the folder this trigger is in | |
globalProps |
dictionary | No | an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
id |
integer | No | a unique id of the trigger, assigned on creation by IndigoServer | |
name |
string | Yes | the unique name of the trigger - no two triggers can have the same name | |
pluginProps |
dictionary | No | an indigo.Dict() representing the name/value pairs defined by your plugin for the trigger - plugin developers should publish this information if you want other plugins/scripts to create triggers of this type - see About Plugin Properties below for details |
sharedProps |
dictionary | No | API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use trigger.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so as to not accidentally remove some other plugin's props). |
suppressLogging |
boolean | Yes | true if execution of this trigger will not be logged into the event log | |
upload |
boolean | Yes | true if IndigoServer should attempt to upload this trigger to the interface - will always be false for plugin triggers |
trigger=indigo.triggers[123]
Commands (indigo.trigger.*)
indigo.trigger.delete(123) |
| Parameters | |||
| Parameters | |||
*duplicateName* |
No | string | name for the newly duplicated trigger |
Enable/Disable Trigger
indigo.trigger.enable(123,value=False) |
indigo.trigger.enable(123,value=True) |
indigo.trigger.enable(123, value=True, duration=360, delay=60) |
| Parameters | |||
*value* |
Yes | boolean | True to enable, False to disable |
*delay* |
No | integer | number of seconds to delay before disabling or enabling the trigger |
*duration* |
No | integer | number of seconds before the trigger is switched back to its original state |
Execute Trigger
| Parameters | |||
*ignoreConditions* |
No | boolean | will ignore any conditions associated with the trigger if True (default) and will evaluate conditions if False |
indigo.trigger.getDependencies(123) |
| Parameters | |||
| direct parameter | Yes | integer | id or instance of the trigger to get the dependencies for. |
ID : 552463741 (integer)
ID : 296710860 (integer)
| Parameters | |||
*value* |
Yes | integer | id or instance of the folder to move the trigger to |
| Parameters | |||
While several of a trigger's properties are read-only (the trigger ID for example), other properties can be changed programmatically. These are noted as "writeable" above. For example,
# Change a trigger's name:
trigger.name = "My new name."
trigger.replaceOnServer()
DeviceStateChangeTrigger
deviceId |
integer | Yes | the unique device id | |
stateChangeType |
kStateChange | Yes | the type of state change | |
stateSelector |
kStateSelector | Yes | can use either a string or one of the enumerations listed in the state selector enumeration | |
stateSelectorIndex |
integer | Yes | a 0-based integer value to specify which of multiple options to monitor - see the About State Selector section below for more information | |
stateValue |
string | Yes | the value the current state should be compared against - will be converted to the right type by the server |
State Change Type Enumeration
| indigo.kStateChange | ||
BecomesEqual |
*stateSelector* becomes equal to *stateValue* |
*ActiveZone* \ AnalogInput \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput |
BecomesFalse |
*stateSelector* becomes *False* |
*BinaryInput* \ BinaryOutput \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ Zone |
BecomesGreaterThan |
*stateSelector* becomes greater than *stateValue* |
*AnalogInput* \ BrightnessLevel \ HumidityInput \ SensorInput \ SetpointCool \ SetpointHeat \ TemperatureInput |
BecomesLessThan |
*stateSelector* becomes less than *stateValue* |
BecomesNotEqual |
*stateSelector* becomes not equal to *stateValue* |
BecomesTrue |
*stateSelector* becomes True |
Changes |
*stateSelector* has any change |
*ActiveZone* \ AnalogInput \ AnalogInputsAll \ BinaryInput \ BinaryInputsAll \ BinaryOutput \ BinaryOutputsAll \ BrightnessLevel \ HumidityInput \ HumidityInputsAll \ HvacCoolerIsOn \ HvacFanIsOn \ HvacFanMode \ HvacFanModeIsAlwaysOn \ HvacFanModeIsAuto \ HvacHeaterIsOn \ HvacOperationModeIsAuto \ HvacOperationModeIsCool \ HvacOperationModeIsHeat \ HvacOperationModeIsOff \ HvacOperationModeIsProgramAuto \ HvacOperationModeIsProgramCool \ HvacOperationModeIsProgramHeat \ OnOffState \ SensorInput \ SensorInputsAll \ SetpointCool \ SetpointHeat \ TemperatureInput \ TemperatureInputsAll \ Zone |
State Selector Enumeration
| indigo.kStateSelector | |
ActiveZone |
monitor the sprinkler’s activeZone to become =, !=, or any change |
AnalogInput |
monitor (one of) the analog input(s) available on the device for =, !=, <, >, or any change - stateSelectorIndex is required to be in the range of available inputs |
AnalogInputsAll |
monitors all of the analog inputs available on the device for any change |
BinaryInput |
monitor (one of) the binary input(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available inputs |
BinaryInputsAll |
monitors all of the binary inputs available on the device for any change |
BinaryOutput |
monitor (one of) the binary output(s) to become true, false, or any change - stateSelectorIndex is required to be in the range of available outputs |
BinaryOutputsAll |
*BrightnessLevel* |
monitor the brightness level of a device for =, !=, <, >, and any change |
HumidityInput |
monitor (one of) the humidity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
HumidityInputsAll |
monitors all of the humidity sensors available on the device for any change |
HvacCoolerIsOn |
monitor the thermostat for any time the air conditioning turns on, off, or has any change (coolIsOn is the current compressor state) |
HvacFanIsOn |
monitor the thermostat for any time the fan turns on, off, or has any change (fanIsOn is the current fan state) |
HvacFanMode |
monitor the fanMode of the thermostat for any change |
HvacFanModeIsAlwaysOn |
monitor the fanMode of the thermostat for a change to/from kFanMode.AlwaysOn |
HvacFanModeIsAuto |
monitor the fanMode of the thermostat for a change to/from kFanMode.AutoOn |
HvacHeaterIsOn |
monitor the thermostat for any time the heater turns on, off, or has any change (heatIsOn is the current heater state) |
HvacOperationMode |
monitor the hvacMode of the thermostat for any change |
HvacOperationModeIsAuto |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.HeatCoolOn |
HvacOperationModeIsCool |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.CoolOn |
HvacOperationModeIsHeat |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.HeatOn |
HvacOperationModeIsOff |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.Off |
HvacOperationModeIsProgramAuto |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramAuto |
HvacOperationModeIsProgramCool |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramCool |
HvacOperationModeIsProgramHeat |
monitor the hvacMode of the thermostat for a change to/from kHvacMode.ProgramHeat |
KeypadButtonLed |
FIXME |
OnOffState |
monitor the device for a change to/from on/off |
SensorInput |
monitor (one of) the sensor input(s) available on the device for =, !=, <, >, or any change - stateSelectorIndex is required to be in the range of available inputs |
SensorInputsAll |
monitors all of the sensor inputs available on the device for any change |
SetpointCool |
monitor the cool setpoint of the thermostat for =, !=, <, >, or any change |
SetpointHeat |
monitor the heat setpoint of the thermostat for =, !=, <, >, or any change |
TemperatureInput |
monitor (one of) the temperature sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
TemperatureInputsAll |
monitors all of the temperature sensors available on the device for any change |
Zone |
| python
folder=1234) |
| Parameters | |||
*description* |
No | string | the description of the trigger |
name |
Yes | string | the name of the trigger |
*folder* |
No | integer | id or instance of the folder in which to put the newly created trigger |
theTrigger.deviceId = 738
theTrigger.stateValue = 80
theTrigger.replaceOnServer()
EmailReceivedTrigger
Property |
Writable | Type | Description | |
emailFilter |
kEmailFilter | Yes | the type of email filter based on the *kEmailFilter* enumeration below |
emailFrom |
string | Yes | if *emailFilter* is *MatchEmailFields*, the value to match against the sender’s address |
emailSubject |
string | Yes | if *emailFilter* is *MatchEmailFields*, the value to match against the subject line |
Email Filter Enumeration
| indigo.kEmailFilter | |
AnyEmail |
when any email is received |
MatchEmailFields |
when email subject/from fields match |
Commands (indigo.emailRcvd.*)
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
InsteonCommandReceivedTrigger
deviceId |
integer | Yes | the unique device id - only used if commandSourceType is DeviceId |
command |
kInsteonCmd | Yes | the command to watch for | |
commandSourceType |
kDeviceSourceType | Yes | the source type - for INSTEON only DeviceId and AnyDevice apply - and deviceId above will only be used if set to DeviceId |
buttonOrGroup |
integer | Yes | the button or group number from which the command is received - see About Button or Group Numbers below for details |
INSTEON Command Enumeration
| indigo.kInsteonCmd | |
AllBrighten |
when an all brighten command begins |
AllDim |
when an all dim command begins |
AllInstantOff |
when an all instant (fast) off is received |
AllInstantOn |
when an all instant (fast) on is received |
AllOff |
when an all off is received |
AllOn |
when an all on is received |
AnyCommand |
when any command is received |
Brighten |
when a brighten command begins |
Dim |
when a dim command begins |
InstantOff |
when an Instant (Fast) off is received in response to a double-tap |
InstantOn |
when an Instant (Fast) on is received in response to a double-tap |
Off |
when an off command is received |
On |
when an on command is received |
StatusChanged |
when a status change broadcast is received |
*NoDevice* |
when the source uses no device or address (only used for X10 RF A/V remotes) |
Device |
when the source is an existing device, the ID is specified |
Address |
when the source is a raw X10 address |
AnyAddress |
when the source is any X10 address or INSTEON device |
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
theTrigger.buttonOrGroup = 1
InterfaceFailureTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
InterfaceInitializedTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
PluginEventTrigger
pluginId |
string | the unique ID of the plugin, specified in the Info.plist for the plugin (or it’s documentation) |
pluginTypeId |
string | the id specified in the Events.xml (or it’s documentation) |
Create a trigger. You can create triggers using this method of any type except for events that are defined by your plugin (that class, PluginEventTrigger, has its own create() method). This method returns a copy of the newly created trigger. Once a trigger of this type is created, the properties can change (via the pluginProps in the Trigger base class), but nothing else can be changed.
| python
folder=1234),
pluginTypeId="myEvent",
props={"propA":"value","propB":"value"} |
| Parameters | |||
*description* |
name |
*folder* |
*pluginId* |
No | string | the plugin id of the plugin that owns the device you're creating - if it's not present, it defaults to your plugin's id |
*pluginTypeId* |
Yes | string | this is the id of the |
*props* |
No | dictionary | this is the properties for the trigger - they will be inserted in to the pluginId's property space as supplied above. If you are creating a trigger of a type defined in a different plugin, it's that plugin's id and properties. |
PowerFailureTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
ServerStartupTrigger
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
X10CommandReceivedTrigger
address |
string | if commandSourceType = Address, the full X10 address to listen for or just the house code if command is All* or AnyCommand | |
avButton |
kX10AvButton | if command = AvButtonPressed, the A/V button to monitor | |
deviceId |
integer | if commandSourceType = Device, the unique device id | |
command |
kX10Cmd | the X10 command to watch for | |
commandSourceType |
kDeviceSourceType | the type of source specified for this trigger |
X10 Command Enumeration
| indigo.kX10Cmd | |
AllOff |
AllLightsOff |
when an all lights off is received |
AllLightsOn |
when an all lights on is received |
AvButtonPressed |
when an A/V button press is received |
AnyCommand |
Brighten |
Dim |
ExtendedData |
when an extended data X10 command is received |
Off |
On |
PresetDim |
when a preset dim command is received |
StatusOffResponse |
when a status off response is received |
StatusOnResponse |
when a status on response is received |
X10 A/V Button Enumeration
| indigo.kX10AvButton | |
| Value | Value |
*0* |
*Left* |
*1* |
*Menu* |
*2* |
*Mute* |
*3* |
*Pause* |
*4* |
*PC* |
*5* |
*Play* |
*6* |
*Power* |
*7* |
*Recall* |
*8* |
*Record* |
*9* |
*Return* |
AB |
*Rewind* |
ChannelDown |
*Right* |
ChannelUp |
*Stop* |
Display |
*Title* |
Down |
*Up* |
Enter |
*VolumeDown* |
Exit |
*VolumeUp* |
Forward |
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
myTrigger.address = "F7"
myTrigger.replaceOnServer()
VariableValueChangeTrigger
variableChangeType |
kVarChange | the type of variable change to monitor | |
variableId |
integer | the unique variable id | |
variableValue |
string | the value to compare against the variable’s value if *variableChangeType* is =, !=, >, < |
| indigo.kVarChange | |
BecomesEqual |
variable value becomes equal to |
BecomesFalse |
variable value becomes false |
variable value becomes greater than |
BecomesLessThan |
variable value becomes less than |
BecomesNotEqual |
variable value becomes not equal to |
BecomesTrue |
variable value becomes true |
Changes |
variable value has any change |
| python
folder=1234) |
| Parameters | |||
*description* |
name |
*folder* |
