Getting Started Guide
Welcome to Indigo 2025.1!
Z-Wave
- Thermostats, and
- Locks.
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
The Indigo 2025.1 application can be found here:
/Applications/Indigo 2025.1.app
/Library/Application Support/Perceptive Automation/Indigo 2025.1/
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2025.1 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
/Library/Application Support/Perceptive Automation/Indigo 2025.1/Web Assets/
Indigo 202x.y->Stop Servermenu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 202x.y->Quit Indigomenu item. - Open the
Indigo 2025.1->License Details...menu item and clicking theDeactivate Licensebutton. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first) - Copy this folder over to the new Mac:
/Library/Application Support/Perceptive Automation/Indigo 2025.1/(if restoring from a backup, you'll need to locate this folder in whatever backup system you use) - Install Indigo 2025.1 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
!!! warning "NOTE"
this is not the Library folder that's in your home directory - it's the one at the top level of your hard drive. The easiest way to get there is to select the Go->Go To Folder... menu item in the Finder and paste in this:
It'll open the correct folder and you'll see the "Perceptive Automation" folder - that's the one you want to copy over. That should get all of your customizations and allow the installer to update anything as necessary. You may also need to install the drivers for the technology you use - see the appropriate section below for details.
If you're moving Indigo to a Mac with a different architecture, read on...
When you move your Indigo installation from one macOS architecture to another (for example from an Intel-based Mac to an M-series Mac) -- especially if you use Migration Assistant or Time Machine -- you will likely need to take additional steps because many Python libraries are compiled to the specific hardware they're installed on. One signal that this has become an issue is an error message like:
- manually remove the
Indigo 2025.1->Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset
Go->Go to Folder… - In the resulting dialog, copy and paste the following:
/Library/Application Support/Perceptive Automation/Indigo 2025.1/Preferences/ - In the resulting Finder window, delete the folder named
In some cases, you may wish to transfer your license to another user--for example, if you sell your home along with the Indigo system. We are happy to assist you in this process, and there are only a few steps you need to take. It is important that the steps be taken in this order:
- When we're done with that, the new owner will need to deactivate/reactivate the license by selecting the Indigo 20XX.Y -> License Details... menu item and first clicking on the Deactivate License button then--in the resulting dialog--log in using the username/password they created in the step 1 above.
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2025.1->License Details... menu item and clicking the Deactivate License button. You'll get the following warning dialog:
Then make sure that you have the server and client completely shut down (select Stop Server from the Indigo 2025.1 menu if the server is still running before you quit the Indigo Mac Client).
/Library/Application Support/Perceptive Automation/Indigo 2025.1/~(your user folder)/Library/LaunchAgents/com.perceptiveautomation.IndigoServer2.plist- Optional : If you don't use Python 3.11 for anything (other than Indigo 2025.1), you can delete this folder:
Uninstalling the Mac Client
/Applications/Indigo 2025.1.app~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-2025-1.plist~(your user folder)/Library/Preferences/Indigo 2025.1 Client Prefs.indiPref~(your user folder)/Library/Preferences/Indigo 2025.1 Client Settings.indiPref
To uninstall older versions but leave 2025.1 installed correctly, delete these:
Indigo 2024.2:
/Library/Application Support/Perceptive Automation/Indigo 2024.2//Applications/Indigo 2024.2.app
Indigo 2024.1:
/Library/Application Support/Perceptive Automation/Indigo 2024.1//Applications/Indigo 2024.1.app
Indigo 2023.2:
Indigo 2023.1:
Indigo 2022.2:
Indigo 2022.1:
Indigo 2021.2:
Indigo 2021.1:
Indigo 7.5:
Indigo 7.4:
Indigo 7.3:
Indigo 7.2:
Indigo 7.0 and 7.1:
Indigo 6 and prior (substitute the previous version # for 6):
Starting Indigo Server
- Double click the
Indigo 2025.1application (/Applications/Indigo 2025.1.app). - If this is the first time to run
Indigo 2025.1on this Mac, then press theStart Local Server...button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 2025.1->Start Local Server...menu item.
Standard startup mode
Outgoing reflector port selection: Some ISPs, especially satellite providers, may block incoming and outgoing connections -- particularly if they sit idle for a time (which, in our opinion is ridiculous) -- this setting provides a few options to hopefully work around these limitations. The setting you choose does not have any impact on performance. Further, the reflector port selection (or, in fact, the reflector itself) should have no impact on local web traffic performance (since the reflector isn't involved when a local network connection is made). If you're experiencing slowness with a local connection, check your router to ensure it isn't blocking or otherwise interfering with Bonjour traffic.
Custom single app startup
Starting the Server
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 2025.1application (inside/Applications/Indigo 2025.1.app) on the remote Mac. - If this is the first time to run
Indigoon this remote Mac, then press theConnect to Remote Server...button in the connection status window. - If you are wanting to connect to a different Indigo Server, then select the
Indigo 2025.1->Connect to Remote Server...menu item. - Enter the
Connectbutton.
http://192.168.1.23:8176/
The first thing you'll notice is the dot beside the names in that menu. A green dot means that the interface is enabled. If the dot is gray, it means that it's disabled. This allows you to see what's enabled by just looking at the menu. Each interface (and its submenu) is described below. If you select the Manage Interfaces... menu item, it will open the Preferences dialog with the Interfaces tab selected:
- Configuring and Managing your Z-Wave Network
- Configuring and Managing your Insteon Network
- Configuring and Using X10 devices
- Using the Virtual Devices Interface
Managing Plugins
Installing/Updating Plugins
- Click the
.indigoPlugin. Double-click that file.\
- You will be switched to the Indigo Client app, and you'll a dialog window which asks you if you want to install and enable the plugin. You will see a different dialog if the version number is lower than an already-installed version; for safety, Indigo will ask you to confirm that you want to downgrade the plugin.
- NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the
Open Withmenu item, then select Indigo 2025.1.
- Click the
Plugin Menus in Indigo
Main Plugins Menu
Individual Plugin Submenu
The next section contains:
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2025.1->Preferences... menu item and clicking the Plugins tab or by selecting the Plugins->Manage Plugins... menu item discussed above.
- the
Uninstalling a Plugin
Help->Show Indigo Server Install Foldermenu item. This will switch you to the Finder and open a window to the Indigo install folder. - Switch back to Indigo and shut down the Indigo Server by selecting the
Indigo 2025.1->Stop Servermenu item in the Mac client (you can leave the client app running). - In the Finder window opened in step 1, you'll see two folders:
PluginsandPlugins (Disabled). Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. Check to make sure that somehow there aren't plugins in both locations. - Switch back to the Indigo 2025.1 Mac client and click on the
Start Local Server...button in theServer Connection Statusdialog.
- Choose
Date & Timeicon. - Select the
Closet Citylocation is not near your location, then follow the instructions on the panel to choose your location. If you would like to precisely specify your location, then you can override the system location from within Indigo.
- Choose the
Indigo 2025.1->Preferences...menu item, then make sure theSunset & Sunrisetab is selected. - Select the
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2025.1->Preferences... menu item) and clicking on the General tab.
You can have Indigo check for updates immediately by selecting the Indigo 2025.1->Check for Updates... menu item.
- Choose
Energy Savericon. - Move the
Where to Go Next
